and other questions
So far, I have the ignition control plug, the power and the ground hooked up. What do I need to do with the magnetic pick-up, weatherpack connector, H/S retard input, RPM switch output, and the staging control input. Please answer if you can.
Re: Ignition question
Anyone? I still don't know how to hook it up. Can anyone help me hook this up with my nitrouse?
are you using an MSD?
I probably should have specified. I am using a Mallory 685. I have no idea how to hook it up with conjunction with my n20 kit.
Ok, can someone at least answer me this. Would I call NX, or Mallory for technical support on this?
aaaaaanyone?
Ok, well, I'll give Mallory a call, but thanks for the help.
Allright....well I contacted Mallory, and here is the response I got this.
"The violet wires are for the NOS. Ground one of the wires and the other is a ground to the NOS solinoid to activate it. What I recommend is that you get a horn reley and use the violet wire as the ground to activate it and send the 12 volts power to the solinoid. This is a more positive way to wire it in. " The only problem is I only see one violet wire on my ignition and I still don't know what to do with the remaining yellow and orange wire. I contacted them again and they said the same response. I am really frustrated. How can I do this if even mallory can't help me out? If you know at all about this PLEASE for the love of god, guide me on how to do this! :cry: |
I could help if I knew what wire did what on the mallory. Do you have a manual or anything? Or do they have the manual on their website?
Ok, it looks like this is the manaul:
http://go.mrgasket.com/pdf/685_6851.pdf |
You set the RPM window switch on the unit, then when it is in that range, the violet wire will be grounded. So you could use a relay:
86 violet wire from mallory 85 b+ 30 b+ 87 switched b+ that will have power when 86 is grounded to put power to your nos solenoid I got that from the top of page 12. You got the Hyfire VI ? |
The yellow is the H/S retard input (+12 volts activates), the violet is the RPM switch output, the orange is the staging control inpu (+ 12 volts to avtivate).
Yes, I have the hyfire 685 IV. I am understanding the window switch, what I don't understand is the yellow h/s retard input.
Buy the wiring harness from Jegs. Problem solved.
Wrong yellow wire. I allready have the wiring harness, it doesn't include ALL the wires.
| All times are GMT -5. The time now is 10:16 AM. |
