Help with a NOS plate
Old 06-08-2017, 02:09 AM
crazypurgatory's Avatar
Question Help with a NOS plate
So I was able to find a NOS nitrous plate and I have some questions I can seam to find the answers to.
1. Does any body know what length bolt's I need? m8x1.25x?
the plate is 12.5 mm thick.
2. It looks like when this plate is on there the intake elbow the stock rubber one will be crusted into the rad support. am I going to have a problem there?
3 the jets I have are nos .055 gas 43 what do I have there a 100 shot? are they the right jets?
4 Is there a chart some where that will tell me what kind of power I will get with different jet combinations at the LT1's fuel presser.
5 are there going to be other problems that I am going to run into because this kit that this plate came from seams to be designed for the older tuned port injection engines.
The guy I got it from was running it on a LT1 in a caprice.
Thanks for any help you can give me.
crazypurgatory is offline
