...........fpss
Old May 19, 2007 | 06:48 PM
mcssmostwanted's Avatar
...........fpss
before or after the fuel solenoid
Old May 19, 2007 | 07:15 PM
2000GTP's Avatar
Before. I have a 6" AN line connected directly to the Schrader valve. The FPSS then connects to that line and another AN line goes from the other end of the FPSS to the fuel solenoid.
Old May 19, 2007 | 07:21 PM
could i just connect it to the fuel noid? or should i just run another line?
thanks bro
Old May 19, 2007 | 07:25 PM
2000GTP's Avatar
The FPSS actually is connects to a manifold via a NPT fitting. You could run the manifold directly off the solenoid, I didn't because of the dimensions, it creates clearance issues.
http://www.nitrousoutlet.com/catalog...roduct_id=1643
Old May 19, 2007 | 07:29 PM
Sinister95Z's Avatar
Definetly before. Here is how I did mine. Earls 90* right into the manifold adaptor and then a AN hose directly to the shrader valve. Very easy to do.
Old May 19, 2007 | 07:30 PM
u da man if only i could get you guys to answer my questions about my tranny swap
