Does nitrous...
Does nitrous clean the motor out, I sprayed a half bottle threw it and it seems to run smoother now? The car loves the stuff... :yes:
Oh yea it will clean out a lot of crud, piston rings, ring lands, valves, and rods sometimes ;)
Originally Posted by slowride94z
(Post 5978824)
N2O does not break down into nitrogen and oxygen until it reaches about 600*F, so its unlikely that it would affect anything up to and including the intake valve. Its sure going to clean your plugs off if you have a "too hot" plug... but that might include removing the ground strap as well.
Shell is currently advertising "nitogen fortified" gasoline. How would a gas that doesn't burn "fortify" gasoline? When you check into what they are actually selling, its a nitrogen-based detergent compound (additive) that is supposed to clean the valves..... misleading advertising at best. |
Originally Posted by Z-RATED94
(Post 5979003)
LOL ,I guess it would if not set up right. On the other hand, after spraying my first couple of times, the next time out on motor I ran my best ever NA pass. Could have been better air, but I think the nitrous cleaning had something to do with it also. :D
Oh yea it will clean out a lot of crud, piston rings, ring lands, valves, and rods sometimes haha I didnt take any short cuts, so it should be safe right :eek:? FPSS, pulled -3 of timing, a/f ratio is at 11.8-12.0 tr6 @.036 and I only run 93 octane. :yes: Im more worried about the glass tranny taking a dump...
Originally Posted by Injuneer
(Post 5979022)
Shell is currently advertising "nitogen fortified" gasoline. How would a gas that doesn't burn "fortify" gasoline? When you check into what they are actually selling, its a nitrogen-based detergent compound (additive) that is supposed to clean the valves..... misleading advertising at best. Interesting.... :think: |
| All times are GMT -5. The time now is 07:59 AM. |
