400rwhp n/a, how much spray on stock bottem end?
I should be right at 400rwhp n/a with my heads/cam setup. See sig for details. I'm looking at high 11.3x's on motor here soon so how much do you think I could spray? I'm thinking a 75 shot just to get in the 10's. I'm a little more worried than the average person since I already have 400rwhp. Any ideas?
Originally posted by 1982z28with18s
K, probably will be a rod.
i plan to have a window switch from 3000-6000 rpm
100 octane, and i will dyno it on the spray to make sure the a/f is correct....
i dont plan to spray until 2nd gear....
C16 gas. Or the highest thing you can find. You should be ok with a 75. People spray more and get away with it. I would do it on a dyno first and pull more timing. But hitting the juice out of the hole will help your 60ft. big time.
Werd. There are a lot of guys still running stock sb with n2o. I would say you'd be fine with a 150 or so.
Also, you're NOT going to get into the 10s w/ a 75 shot. Moreover, with 400 on tap NA, you won't even feel the 75 more than likely...
Jon
Jon
Jon
Jon
Originally posted by DrewHMS97SS
most ppl i have heard of drop about a second on a 100. so yes 75 shoud do a 10 if you are 11.3 on motor
I don't see me having a problem hitting 11.3x on motor with decent weather and the little mods I have coming up.
