Mountain Arizona, Colorado, Idaho, Montana, Nevada, New Mexico, Utah, and Wyoming
New Smog Laws???
Old Oct 15, 2003 | 01:08 AM
  #16
Fatdog's Avatar
Cool
I always change the oil right before the test,and sit in the parking lot and idle till the car gets real hot.Seems the smog test likes a real hot(temp) motor.(Can't people with headers use O2 heaters ,to help pass smog,I dunno,anybody?).
Old Oct 15, 2003 | 12:42 PM
  #17
CSULAZ28's Avatar
Originally posted by lt1hatesme
what if the car is modified with headers and a cam?? i plan on putting in a new cam, nothing rediculious, but it might change the idle a bit. if it still passes will your "guy" check on EO numbers and say my headers arent good enough?
Don't worry about it. You could have a full nitrous setup in your car and you'll still get hooked up. a cam with LT headers is absolutely fine. EVen if you had no cats, you'll be all right.
Old Oct 15, 2003 | 05:02 PM
  #18
SS MPSTR's Avatar
Originally posted by cnorton
The technician was fairly conscientious about the visual, even going so far as to shine a flashlight into the hood scoop openings to see if they'd been modified.
Your technician was a moron. What on earth do modified hood scoop openings have to do with emissions?
My '97 passed with no problem, and my technician 'saw' that I had two cats on the car. Passed visual with no problem. I was asked if the parts visible had EO #'s and I replied "Of course."
Old Oct 15, 2003 | 06:15 PM
  #19
mystic98Z's Avatar
I have never heard of O2 heaters before. Anybody else know about these things. I could definetly use any information on how to pass smog with a cam and LT headers on.
Old Oct 16, 2003 | 12:20 PM
  #20
Wild1's Avatar
I think he is referring to Heated O2 Sensors. The heated O2 sensors have 4 wires going to the connector. Mine is a 1995 and has only 2 wires. It could be an OBD-II requirement after 1996.
Old Oct 16, 2003 | 01:21 PM
  #21
snorkelface's Avatar
Re: New Smog Laws???
Originally posted by drewstealth
Somebody told me that they are started new smog laws Oct. 1, is this true? What is new about them? Because i'm gonna be doing the AS&M single cat conversion to my car and i'll be able to pass the sniffer but not the visual. Thanks.
Those AS&M headers wouldn't pass under the current smog laws anyway. Under the current laws, you cannot remove a cat, relocate a cat, or even change one out to an aftermarket one in the stock location. I was able to get away with my Random Tech Y-pipe because it still had two cats because they didn't know that the drivers side cat was moved further back from stock. Technically though, it's illegal.
Old Oct 16, 2003 | 05:45 PM
  #22
drewstealth's Avatar
Yeah i know it is technically illegal but it will still pass the emissions part of it. Do you think they will know if its supposed to have 2 cats?
Old Oct 16, 2003 | 05:55 PM
  #23
Wild1's Avatar
Some check the cars some don't... hit and miss. Technically, any modification is considered tampering. Moving Cat-Converters is a bad thing in Cali even though it passes smog. Ask the politicians what is important, clean running cars or equipment location.
Old Oct 16, 2003 | 05:58 PM
  #24
They may not memorize the exact location of where the cat should be, but I'm sure they have a spec sheet that will tell them the number of cats a vehicle should have. I'd go with some smog-legal headers and a good y-pipe. Headers are just too obvious of an external mod to not draw attention to them.
Old Oct 17, 2003 | 01:21 AM
  #25
Well i don't really wanna get the shorties made for my car because i have heard the gains aren't much on dual cat shorties. I think i will definetly be screwed with lt's but with mids i think i will be able to get by hopefully. The as&m's from what i hear are the best headers besides lt's.
Old Oct 17, 2003 | 01:26 AM
  #26
Wild1's Avatar
Have you considered MACs for Mid-lengths?
Old Oct 17, 2003 | 01:31 AM
  #27
yes but they are only 1 5/8's and the as&m's are 1 3/4's. I know there isn't to much of a difference but i'm sure it does matter and i rather do it right the very first time.
Old Oct 17, 2003 | 01:32 AM
  #28
Wild1's Avatar
You'll appreciate the 1 3/4 if you go with boost too. Ok, you've done your homework. A+
Old Oct 17, 2003 | 02:03 AM
  #29
Yeah i have done a lot of researching on headers before i decided on the as&m for sure. I was about to order them tomarrow but since my SLP clutch went out after 5,000 miles i now have to spend $800 or more on a new mcleod clutch setup. Just the single disc though. I don't feel like replacing my rear end right now.
Old Oct 17, 2003 | 02:16 AM
  #30
z28racn's Avatar
I purchased from thunder racing about 3 years ago an arizona speed and marine equal length shorty headers with a random tech y pipe and dual cats. I love the setup and I have had no probs at all until I had a cat go out on me. If you are interested in full length headers on a car that is basically a race car that still passes smog check out this characters web page. It is probably one of the best LT1 sites on the web, http://para.noid.org/~lj/
Anyways got any question about my cats and exhaust you can e-mail me if you like. I have posted once before a number you can contact to try to get more info about what we can and cannot do to our hot rods.
In case you are wondering here it is 800-622-7733.
93 RedBird
Nov 15, 2015 08:24 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
colts0455
Jul 8, 2015 12:21 AM
cristian1311
Jun 27, 2015 11:55 AM
