Mountain Arizona, Colorado, Idaho, Montana, Nevada, New Mexico, Utah, and Wyoming
383
Old Oct 10, 2007 | 10:59 AM
ComptonZ28's Avatar
Question 383
OK, I'm in CA, so tha smog regulationz suck... any advice on how 2 run a 383 "Cali" style? What partz do u reccomend 2 build it?
Old Oct 10, 2007 | 05:31 PM
kick Z tail out's Avatar
Talk to the guys at AI.
Old Oct 11, 2007 | 01:03 PM
ComptonZ28's Avatar
What'z AI?
Old Oct 13, 2007 | 09:36 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
A 383 in an LT1 is not a big deal to make pass the smog test. Just make sure your headers are CARB approved with the EO number. Pick a mild camshaft, something in the 220-230 intake duration with 112-114 LSA, pair it with a good set of heads like AFR's or Trick Flow's, and find someone to do the custom tuning in the PCM (I can do 92-94 LT1's), and you're in business.
Old Oct 31, 2007 | 05:21 PM
ComptonZ28's Avatar
Thumbs up
OK, thanx 4 tha advice... I think I'm gonna go 383...
Old Nov 7, 2007 | 12:10 AM
Wild1's Avatar
Good advice. With the cam, watch the overlap. On a 350, 48 degrees of overlap is the edge of the safe zone. You can get higher with good programming on a dyno.
On a 383, stay below 56 degrees of overlap. If the cam is lopey, then the smog guys get really nervous so keep the idle up.
LS2s are running 6.0s which is a 383 (different engine) but the displacement shows it is possible to pass smog and those are stock. If you've got the money, go for a 383.
www.lnrengine.com is a very good place to go.
Old Nov 13, 2007 | 03:35 PM
blown383's Avatar
Derek @ LNR built my 383. Reasonable prices and the guy is very knowledgeable.
-B
Old Nov 14, 2007 | 12:56 AM
Kevin91Z's Avatar
The LS2 6.0L is 364 cubic inches, not 383. 383 cubic inches is 6.25L.
Old Nov 14, 2007 | 11:45 PM
Wild1's Avatar
Oops. Your right, it isn't 383 cu in. On the volume calculator it came out to 366 cu in.
Old Dec 13, 2007 | 07:24 PM
ComptonZ28's Avatar
Talking
OK, I'll check them out, thanx again 4 tha info...
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
