Need help diagnosing a problem with a car
It's my nephew's 1992 Chevy Astro. It has a 4.3l V-6. You start the thing up and it runs fine when it's cold. Once it warms up, it doesn't want to run any more. It won't idle and will only run if it is in park and someone is revving it at least 1500 rpm. Put it in drive and it dies. Anybody have any idea what it could be? Seems like it would have to be a fuel system or throttle body problem. Also, you don't get an SES light or any other idiot light.
Anybody have something that pulls codes that I could borrow? Even without an SES light I'm thinking it might be throwing some codes.
Originally posted by Hot Rod Hawk
egr will cause a major vacuum leak when they fail.
They also have heavy carbon deposits build up on the pintale and it cause's a vac leak...stalling, nopower, etc.
good luck
chris
My money's on the EGR. I had a 93 S10 Blazer and it happened twice. Both times it was after it had been run on the highway so it was warmed up. Come to a stop sign and it sputtered and stalled.
Replaced the egr and it fixed it. I was told it was pretty common for carbon to build up there and cause it to hang open.
Bob
Bob
Scott,
I can scan it for ya if you need it. I think i know what it is. Does it have a 700R4 trans? If so unplug the TC lock up selinoid(sp) then start it up and put it in drive ....you might have to do that till it unlocks then it should run fine. Any ?'s or need help call me @ 313-607-6637. Steven
IT SOUND'S LIKE IT IS THE COLLENT SENDING UNIT FOR THE ECM.
IT MIGHT BE UNPLUGED, OR BAD. IT WILL RUN GOOD WHEN IT IS COULD, BUT RUN LIKE SH*T WHEN IT WORMS UP. ONE SINE OF THIS IS RUNNING RICH.
*back from the dead*
My 94 Bravada needs a new EGR valve - and I honestly havent done too much to it, nor looked hard at the 4.3L CPI Vortec...
A garage wanted $627 to replace the EGR valve, Plenium gasket, and do a fuel system cleaning... ditch the cleaning, and we're still talking $550+...
I looked up at Napa and I can get the EGR valve for $45 and the gaskets for under $15. How hard is it to replace the EGR valve on these buggers? Any tips/advice? I know on the lt1 it's easy... does this follow suit?
Originally posted by triumph
It is easier! The 4.3 vortec it should be right in front. 5 minute job. Steven
On my nephew's van, it was on the back of the motor. Very easy to access once the cover was off. Hell, it took us longer to get the cover under the dash board off then it did to pull the EGR valve.
In his case, it turned out someone that was unhappy with him put sugar in his gas tank. Fresh gas and fuel pump and he was all set (until he rolled it a couple weeks ago).
