Need help, delete code
I've heard that you can delete SES codes for good with ls1 edit, is this true?? If so, does anyone around the lansing or detroit area have ls1 so that I could load it on to my computer and use it? I really need this bad, any help would be apprciated. Thanks guys.
Re: Need help, delete code
Originally posted by longgunn I've heard that you can delete SES codes for good with ls1 edit, is this true?? If so, does anyone around the lansing or detroit area have ls1 so that I could load it on to my computer and use it? I really need this bad, any help would be apprciated. Thanks guys. |
That sucks, well, if I do get edit will it take care of my codes?
You can probably toggle off the codes but it would be less expensive to have a local shop do it for you. A single user copy of edit is $550 dollars. There's more info here.
| All times are GMT -5. The time now is 06:09 AM. |
