Defrost...
For some reason my rear defrost is not working. I checked for a fuse, but didn't see any labeled as such...
PLEASE HELP... |
How do the contacts on the back window look? I've seen 'em break off before.
They all look pretty good from what I can tell.
check to see if you have power at the wire on the hatch, there should be power there w/the switch on. does the sw. button turn on? there should be a relay I believe. look underhood and in the Instrument panel fuse box.
chris |
