Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
355 kit HELP
Old Aug 20, 2004 | 12:16 AM
Schurters LT1's Avatar
355 kit HELP
Is there any speed shops that could put together a 355 kit.
Pistons forged.020/.030 over flat top, i think.deaking the block to zero
Scat 4340 I beam rods 6"
rings
bears
arp nuts and bolts
spring kit of the oil pump
am i missing somthing if so just add it in...
thx
Old Aug 21, 2004 | 06:48 AM
IrocSS85's Avatar
Re: 355 kit HELP
well, not sure what you already have in there, but if its all stock, you at least want
1) timing chain (or true roller timing chain)
2)pistons (depends on what compr. and if your gonna use nitrous/supercharger ever)
3)new valve train (bigger cam, valve springs, hardened pushrods, roller rockers, pushrod guide plates, rocker studs, valve seals,)
4)head work (at the least, Id suggest getting a valve job and get the heads cleaned. but nows a great opportunity to have them ported )
5)ARP main studs (also head studs if you have the money)
6)if your not using nitrous or supercharger, then have the stock crank polished/sized.
7) good piston rings
8)balance the rotating assembly
what are your plans for the engine? what is your power goal? how much cash do you have to spend? I paid $550 to have my block cleaned, bored/honed, decked, cam bearings installed, freese plugs installed. you'll spend another ~$75 to have the crank redone. youd be hard pressed to beat the price of the mail order short blocks. at least shop around on the internet and compare price with the local shops.
good luck though.
chris
Old Aug 22, 2004 | 05:43 PM
AutoRoc's Avatar
Re: 355 kit HELP
Originally Posted by IrocSS85
you'd be hard pressed to beat the price of the mail order short blocks. at least shop around on the internet and compare price with the local shops.
good luck though.
chris
Valid point by the Chris man. If you're not looking to use a lot of "power adder", there are a lot of unbeatable deals out there as far as short blocks go. GM's new ZZ383(cubic inc-425hp), the old ZZ4, ZZ385(HP), Track Pro, Speed-o-motive, Golen's Engines, etc,etc... Goodluck!
Local shops can definately handle a project like you want also and it can be a better experience if you're looking to interact with the build-up.
LeftoverChinese
Jan 14, 2024 03:03 PM
lt1xondeck
Mar 18, 2016 07:22 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
CARiD
Jul 7, 2015 08:19 AM
