Z runs fine cold once warm or "open loop" Missfire at idle begins
Old Oct 30, 2007 | 12:04 PM
qboneus's Avatar
It is relatively mild but I am wondering about what the cause could be.
No missfires apparent under load or while driving but If I pay attention to the car's vibrations at idle or when in N or P I can feel a missfire.
I just recently replaced the opti and the bases gaskets are damaged so I had to rebuild the gaskets with "the right stuff".
the only thing I can think is I didn't get the top two opti cap screws tight enough and the rotor is having to arc farther at the top of the cap??
I know.. grasping straws, and why if this was the case would it run better closed loop vs open loop?
Should I be thinking more Mass airflow\o2's?
Has anyone ever found a way to add tension to the top two torx screws WITHOUT REMOVING the h20 PUMP?
Am I going to damage the engine driving it with a slight missfire If I can only detect it at idle??
Any advice about my queries is greatly appriciated.
thanks,
Tal
Old Nov 2, 2007 | 04:54 AM
Guest47904's Avatar
Guest
Try disconnecting an O2 and see if it runs better even after it is fully warm. If so, you probably have an O2 related problem. Either O2 or wiring.
Do you have headers? If so I would suspect wiring.
Old Nov 2, 2007 | 10:26 AM
94_PatriotRed_Z's Avatar
I had this same problem, and my was a bad opti. Try to have the code read, and then got to shoebox's website and find out what it is http://shbox.com/1/Dtcs.htm, when I had my problem I was throwing code 36
dirtybird81
10
Jan 6, 2015 09:31 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
nophix
Nov 30, 2014 10:26 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
