Yellow toped injectors, stock or not?
i was wondering if anyone here can tell me how i can tell what size injectors i have. If possible if anyone knows the colors that correlate with pounds per hour, i would greatfully appreciate it. My tops are yellow, is this stock or not?
Re: Yellow toped injectors, stock or not?
Accels are what you probably what you have. Here is a link to some http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW hope this helps.
If they are Accel injectors, they will have the size stamped in small black numbers on them.
Why do you have larger injectors? You don't have any mods that require you to have larger injectors. Do you have a tune for the injectors? If not that can cause some problems.
I didnt put them on, the guy who owned it previously im pretty sure he was using spray on the car, so i guess that was part of his setup. I want them out, or would it be better to tune for them, is there a gain of hp in a tune of injectors on a stock car? And will i be able to see the "stamped" size with on them without taking the fuel rails off?
