XE 224/230 on stock heads?
Old Feb 27, 2003 | 11:58 PM
JJ's95B4C's Avatar
I know its another cam quesiton, but i've searched and have not found exactly the questions I want answered. How does this cam work with stock heads? Also, this is my daily driver. I will have a stall converter by then, and my mods are in my sig. How is the driveablility with this cam? And one last question, how does this cam to the CC305 or lt4 hot cam in terms of idle quality? I want the car to idle somewhat smooth. I have LT1 edit too, so tuning is not a problem.
Also, can the cam be ground on a 114 lsa, or is this not a good idea?
Thanks in advance,
JJ
Old Feb 28, 2003 | 12:21 AM
jonaddis84's Avatar
I have it with mildly ported heads, stock valves, it lopes nice, doesnt sound like you have to rev it to keep it running, just sounds awesome, its not programmed yet, i think that will smooth it out a little bit. The torque down low is just sweet, right at 2grand I have more than my tires can handle in 2nd and 3rd gear, without programming mind you. Ive heard it performs really good with stock heads, but so does any other cam, its like any other mod, gives you hp, but works best when you do something else. Unless you are against porting your heads, do it. its ten times easier to pop the heads off than it is to put a cam in. Just handport them and you will see a lot more out of that cam.
Old Feb 28, 2003 | 01:07 AM
drop top steve's Avatar
Great cam, mild with lots of bottom end but pulls to about 6300 with my heads. Slight lope, runs on stock tune but to get the most a tune is required.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
