CamaroZ28.Com Message Board
-   -   would this engine work on my Z?? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/would-engine-work-my-z-92021/)
tealdevil Mar 11, 2003 04:39 AM
http://www.samtaylor.com/html/parts/350_Ho_Engine.htm , will i have any problems with it..
and is it a good engine, also how much to install..
thanxx..
anaik Mar 11, 2003 05:13 AM
That's not an LT1, won't work.
RacinLT1 Mar 11, 2003 06:15 AM
sure it will "work",BUT.....you cant use the stock computer,you will have to figure out what small base distributer to use.
Also will need to go aftermarket EFI/manifold or run a carb and do some cutting of the cowl.
Not a wise choice IMO,but it is possible with a lot of work.
tealdevil Mar 11, 2003 12:16 PM
well here is the deal, i have 120,000 on my engien, so its time to get a new one, but somehow i cant find any new LT1, and rebulding is kind of confusing, i did a search and there is planty of types to chose from, all i want a 350hp engine fly not RW..
so what do i need to rebuild it..
thank u for ur help..
Kris93/95Z28 Mar 11, 2003 12:54 PM
Well try to look around there are MANY companies that rebuild LT1s. That would be just as expensive as buying a new engine and having it installed.
You probably could have a 383 for the price of the engine in the link;)
94_formula Mar 11, 2003 01:15 PM
120k, it should go more than that and stay strong.!!
