Worth getting this chip?
A fellow TA owner I met when I first got my car has offered to sell me two parts. The first I think I will get, a ram air hood. It looks to be in good condition. The second one is a hypertech chip, is it worth getting the chip on a pretty much stock car? I am planning on doing heads/exhaust and possibly pullies this winter. So with that in mind is the chip worth it? (hes selling it for $50 Canadian)
I pretty sure only the 93's have chips. But i could be wrong. But like faceless said its not worth it. Just get a mail order tune. From like Madz28, or pcmforless, there are a few others but i can't remember the names. You will see a little gain over the stock program. But imo i would wait till you have some more mods to get a tune done.
As it has been pointed out, technically, it's not a "chip". The hypertech add in piece goes in between the motor wiring harness and the PCM. '93 f-bodies are the last that utilize a burned chip. I say use your money elsewhere. After you get a good bit of mods, go with either a mail order tune or a dyno tune(dyno would be better).
Originally posted by Seal
you should be running 93 regardless... its in the manual book... ure driving a sports car...
I have the Jet power module stage II and you can tell the diff. I drove a 1996 all stock and then my 1994 for a side by side to see the diff. and you could tell mine ran better, better accel. unless my 1994 was just alot faster then the 1996.
