Wiring question (technical)
Old Oct 21, 2003 | 10:55 PM
jonaddis84's Avatar
I want to wire in an LED light that mounts in the A-Pillar pod with the water temp and oil pressure guages. I have an electric water and mechanical oil, but I have the stock oil still hooked up so I can use it for this.
Im guessing these guages just work off of Ohms of resistance from the sending unit and it calculates it from there. So in theory you could figure out what the resistance is at say 200 degrees water temp and put a resistor inline with an LED light so that when it goes past that resistance the light turns on, and same thing with the oil pressure at say 15 psi or something. I just dont look down at my guages as often as I should and I cant keep my eye on them at the track when im trying to drive and shift, so I figure a bright red light will catch my attention out of the corner of my eye letting me know when im in a danger zone.
Question is, is this possible, and would someone be able to figure out these resistance values for me so that I can get this wired up, I dont have a engine right now...
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Jan 4, 2015 11:15 AM
lbrowne
Nov 13, 2011 04:25 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
