Winter Mod List, Help Please
Well here is my winter mod list what else should I consider.
52 or 58mm Throttle Body (which one?)
30lb SVO Injectors
Holley 255 lph fuel pump
Electric Water Pump (Meizere or CSI?)
1.7 Rockers
NX Wet Kit
What gains should I expect from these mods, excluding the NX kit. I know how much it will help.
30lb SVO Injectors
1.7 Rockers
NX Wet Kit
Re: Winter Mod List, Help Please
30lb SVO Injectors
1.7 Rockers
NX Wet Kit
30lb SVO Injectors
1.7 Rockers
NX Wet Kit
I currently have the GMPP 1.6's. here is what originally got me thinking about getting the 1.7s
http://www.kyfbodies.org/vb/showthre...light=scorpion
I have read a someplaces that a tb helps and someplaces say it doesn't. I will research further before buying though. Thanks.
youre gonna need a good ignition setup with timing retard capabilities for the gas. junk the throttle body and 30#ers, you dont need them. spend the extra money on an MSD digital 6+ with launch control and adjustable retard. youre also gonna need a bottle warmer, prob gonna want a purge kit, blow down tube etc
theres a lot more to it than just buying a nitrous kit
Thanks for the n2o advice guys but I have had it on my old Formula and already had it on this Z28 but removed it after the cam install, so I know there is more than just putting on a nitrous kit. I already know what is required for that, but Thanks anyway.
That is why I am going to put the fuel pump and injectors, the injectors may not be needed but I would rather play it safe. Alsoas far as ignition I have an MSD 6A on the car right now.
Now are the electric wp and 1.7's worth the price?
ChrisFrez
Mar 29, 2015 09:43 PM
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Jan 18, 2015 08:05 AM
Dec 1, 2014 08:08 AM
