CamaroZ28.Com Message Board
-   -   will this timing chain work????? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/will-timing-chain-work-427905/)
jkucz31 Feb 4, 2006 12:52 PM
i bought the Lt4 hot cam kit recently and figured i needed a new timing chain so i went to summit racing and ordered this. i was told that this is not going to work i just want to check with you guys first. The part number for summt is CLO-9-131
Javier97Z28 Feb 4, 2006 01:33 PM
Re: will this timing chain work?????
It says it's for a chrysler small block.. so I'm gonna go with no, won't fit ;)
hotrod18_69 Feb 4, 2006 03:29 PM
I'll second that.. Pick up a Extreme Duty set or run to autozone and get a stock replacement.. Make sure you get the whole kit though.. Crank gear, cam gear and chain.. You'll be safer that way replacing it all.. :D
2nd_chances Feb 4, 2006 04:13 PM
You don't need the expensive LT1-LT4 timing set if you switch to an electric water pump. The money saved pays for the new WP.
TheNuge876 Feb 4, 2006 04:33 PM
:yes:
Even if you dont go with the electric water pump. A stock replacement should be fine I've heard of many people using A stock replacement without issues even with heads/cam and all the bolt ons. But the electric water pump is definately a great thing, and then you can get the cloyes double roller timing chain.
