Will A LS1 Clutch Pedal Fit A LT1?
My LT1 clutch pedal sits at the same height as the brake pedal. I've noticed that the LS1 clutch pedal sits higher than the brake pedal and this allows me to push the seat further back from the steering wheel. It's more comfortable and I'm not dangerously close to the air bag. Does anybody know if the LS1 clutch pedal assembly is compatible with the LT1 assembly? The parts look almost the same but I'm concerned with the stroke length and pump volume for the clutch master cylinder. Or does anybody know if the LT1 clutch pedal height is adjustable for height?
10-31-2016 11:09 AM
