will it fit?
will a freshly rebuilt 700r4 transmission out of an 89 iroc z fit into a 95 z28. will it run ok? fit ok? or is it possible or not possible?
thanks |
It'll fit, but it won't work....your '95 shifting is done electronically, the '89 is done mechanically, using the governor...not sure if there's a way to disconnect the trans electrical without throwing codes....
| All times are GMT -5. The time now is 07:58 AM. |
