Will cat back exhaust from 3.8 work on lt1
Re: Will cat back exhaust from 3.8 work on lt1
First, what size is the pipe? Secondly does it y pipe into dual tips out the rear. and thirdly you need to check to see if the catalitic converter is in the same position as the v8 version. I highly doubt it is, since the v8 is much larger and so is the transmision. It may be possible to fab it together but it will probibly be a pain in the neck.
Jul 4, 2005 05:00 PM
Geeterman
Aug 4, 2002 04:03 AM
