Will this cam work with LT1?
Will this cam work? It's from summitracing and it's CC FI CAMS and it's the highest lift cam I've found and it says 92-97. http://store.summitracing.com/partde...5&autoview=sku
Re: Will this cam work with LT1?
yes....it is ground for the LT1 specificly
Is this the most aggresive cam?
bigger is not always better...
what exactly are your goals for the car? |
Well I'm looking for the biggest cam I can get since my cc306 had a worn lobe on the first cylinder. My car is fully modified and I am just looking to have the fastest street car in my city which the fastest at the moment is an LS1 that has 10,000$ in the engine but only pushes 500HP and has nitrous and my setup will do just about 480+ to the wheels so I wanna get the best cam I can get now.
You should talk to SStrokerAce (bret bauer) and see what kind of custom grind he can setup for you.
If you click on the application tab it say "ltx family" and it also says 92-97 so, Yes, It will fit. |
Does anyone know the biggest cam lift you can use with 1.6 ratio rockers? The CC306 is .510/.540 and this is CC468 .584/.579 lift. This cam will be better for me than the CC306 because I have ported and polished heads, tb, and intake. This car needs more fuel and air etc. because it's going to have a higher compression and bigger stroke so I have to feed it with this cam and I guess I need bigger injectors and fuel pump too.
not dure on the biggest...but I am running .613/.590
| All times are GMT -5. The time now is 04:32 AM. |
