Why does my car eat alternators?
Old Nov 16, 2005 | 02:17 PM
OutKast's Avatar
The car is basically a 93Z28 and I can't figure this one out. Thank god for lifetime warranties but damn I'm getting tired of swapping them out. This last one only made it about 7 weeks. I'm not having any electrical problems in the car that would lead me to a cause. I'm not even experiencing any battery drainage if the car sits for several days so I don't think there is a short. Right now I have the relocation bracket that moves it down where the AC was but the problem existed before I did that.
Anyone else suffer from this problem?
Old Nov 16, 2005 | 02:18 PM
n2ceptor's Avatar
Re: Why does my car eat alternators?
Where ar you getting the alts from???
Old Nov 16, 2005 | 02:21 PM
OutKast's Avatar
Advanced Auto right now....all Delcos. I've had em from other parts places also and they have all met with the same fate. I've disected a couple and found that the brushes are fine, it seems like the internal regulators may be getting toasted.
Old Nov 16, 2005 | 05:54 PM
1996z28m6's Avatar
do you have an aftermarket sound system?
Old Nov 16, 2005 | 06:10 PM
tranz28's Avatar
Do you have a bbk underdrive pulley if so you also need the alternator pulley as well.The alternators that you are buying are they rebuilt if so pay a little bit more for the new with the same war i work at autozone 5 years this is a common proublem with rebuilt alternators. If you have a sound system that when it hits you see your dash lights dim that is also a proublem.You need to have your system professional installed with caps a blocks. Jack Brown
Old Nov 16, 2005 | 08:38 PM
OutKast's Avatar
Head unit is aftermarket but no amps or subs pulling alot of power.
I'm running stock pulleys.
Just finished installing a new one tonight so we'll see how long this one makes it. I give it 10 weeks......maybe 12.
Old Nov 16, 2005 | 08:56 PM
OutKast's Avatar
forgot to mention that I also run an optima red top battery so there should be plenty of juice on tap. It's pretty amazing how far I can drive on battery when the alts crap out...so far I've made it over an hour and a half on the battery.
Old Nov 16, 2005 | 09:14 PM
Cmr0z28's Avatar
Try getting a brand new unit and see what happens...
Old Nov 16, 2005 | 10:30 PM
OutKast's Avatar
that's not an option....I'll swap free ones all day long until I find the cause. Aren't new ones like $300+ ?
Old Nov 17, 2005 | 06:53 AM
MentalCaseOne's Avatar
Just a thought.... How hight does the voltage goes up after start up? In my car there is a little wire that connects to the alt. I think it controls the output voltage. I need to look a the schematic though.
I think your alts are crapping out of high temps from high loads. It would be a good idea to have someone measure the Amps being delivered from the Alt to the bat when you start the car.... Thats a good starting point.
Marvin
Old Nov 17, 2005 | 08:14 AM
OutKast's Avatar
I had a similar thought last night but more along the line of somehow being able to put a meter in the car so I can see how many amps are pulled during different situations such as when I spray, run the bottle heater, turn on the fans, etc...
Anyone know if there is a way to install such a meter in the car?
Old Nov 17, 2005 | 11:02 AM
Z28barnett's Avatar
Could be poor rebuilds.
Here is a link to new CS144 alternators.
http://www.alternatorparts.com/CS-144_Special_offer.htm
Z28
Old Nov 17, 2005 | 12:45 PM
NeverEverSatisfied's Avatar
Well there is half of your problem... O-Zone... Also I installed stero's for 4 years with my own shop... What are caps a blocks? Also where the hell do they get these people to work at O-Zone? Professionals?
Old Nov 17, 2005 | 06:55 PM
Guest47904's Avatar
Guest
A bad tensioner can cause alternator problems. By causing a "jerky" motion. We summised that it is shock loading the alternator. We recommend that you change the belt and the tensioner at regular intervals.
nophix
Nov 30, 2014 10:26 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
