CamaroZ28.Com Message Board
-   -   Why do my rockers keep needing adjustment (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/why-do-my-rockers-keep-needing-adjustment-294909/)
94zrag Aug 24, 2004 04:50 PM
I've had to adjust my rockers 4 times now. Everytime I hit around 5000rpm they start clicking and I have to re-tighten them. The're 1.6 NSA pro-magnums, any ideas? How much torque are you supposed to put on the lock nuts?
'94 Bad A Z28 Aug 24, 2004 04:53 PM
Re: Why do my rockers keep needing adjustment
NSA = Non Self Aligning
Non Self Aligning rockers need to be reajusted from time to time, not sure about torque specs though, if they are not tightened to spec that is prolly why they keep chattering (clicking) when you get up in the RPM band, sorry I can't be of more help...
Fastbird93 Aug 24, 2004 05:10 PM
Are you sure about that, or are you thinking of the difference between a hydraulic roller lifter and a solid roller. I've not heard of NSA rockers having to have the lash reset more often than SA rockers.
RE AND CHERYL Aug 24, 2004 05:16 PM
Dumb question, but you did install guide plates. RIGHT... NSA rocker have to have them.
How did you adjust the valves? You don't torque the adjusting nuts. I've got valve covers with the tops cut out. This is what I do.
1 Loosen the center lock screw
2 back off the adjusting nut a few turns until it starts clatering
3 slowly tighten it down until the noise stops
4 tighten 1/2 to 1/2 turn more
5 tighten the center jam nut
RE AND CHERYL Aug 24, 2004 05:19 PM
Just another thought, do you have stock springs and cam? If so your springs may be binding due to light valve float. The stock springs are absolutely at their limits with 1.6 rockers.
94zrag Aug 24, 2004 05:37 PM
When I asked about torquing the nut I meant the center lock nut, not the one that gets adjusted. And the springs were sold to me as part of a package from combination motorsports, so i'm sure everything is supposed to work fine. And yes, I did use the guideplates. This is just confusing me.
popsz28 Aug 24, 2004 09:15 PM
Weak Lifters???
Spinner Aug 24, 2004 10:25 PM
Tighten the center lock nut until it clicks.
