Who all makes OTVC Pre-Cut wires for an LT1 ?
I tried elitesparkplug.com, but the site doesnt exist anymore. Everytime I would type it in at the top of the browser it would redirect me to a yahoo search for it with no link.
I was going to get Taylors, but no plug wire set is worth 120$. I was thinking Moroso Spiral Max's but I dont know if you can get OTVC precuts ... And Everyone ive talked to has told me cut to fit is a pain in the *** and that Taylors are kbnown to arc on the boots so ... Know I dont know what to do ...
Re: Who all makes OTVC Pre-Cut wires for an LT1 ?
Wow, who sell Taylor wire set for $120? Most places sell them for $60. Never heard of pre-cut OTVC wires. I have Taylors and they weren't that bad to put together. I also had MSD 8.5mm super conductors. They were a little easier to put together than the Taylors universal wire set.
Edit: You left off the s. http://www.elitesparkplugs.com
O ... My screw up then. Thanks guys. I'm going to order a set of 9MM OTVC wires later on today. Anyone know where I could get a decently priced set of looms ? I wonder if Advance or NAPA or something would have them ...
I got the EliteSparkPlugs.com wires with 1200* heat shield and Made For You looms and installed them yesterday. They look and fit great! I got the wires for $50 and the looms for another $45.
You can just get a set of Made for you looms from thunderracing.com that are like 10mm. I got 7-8mm looms with 8mm wires with the heatshield, it should work but it may be a little tight.
you can get them cheaper directly from MFY than you can from thunderracing.com.
for 9mm wires youd have to get the 10mm looms.
http://www.made4uproducts.com/
we are still hear ...
check out our OVC wire sets
http://www.elitesparkplugs.com/images/IMG_1079.JPG
http://www.elitesparkplugs.com/images/IMG_1088.JPG
Interesting way of mounting your headers, looks like it would make tightening them very easy. Care to explain what all was done?
On a side not, ill vouce for the elitesparkplugs.com wire set, very nice quality, etc. Only thing i'm upset about is they don't give a coil wire in the kit...
The sheaths around where the header bolts fit were all different lengths, so finding bolts that fit each perfect was near impossible. I just went ahead and filled the small spaces with washers and they've held up for almost 2 years and havent backed out at all!
