Where's the leak?
Old Oct 16, 2003 | 10:51 PM
crzhrs's Avatar
Where's the leak?
My 94 Z-28 is leaking freon, is there any certain spot on these cars that is known to leak? It will hold for a couple days then it will be completely dry.
Old Oct 16, 2003 | 10:54 PM
NewbieWar's Avatar
how do u know its completely dry, how much do u have to put in>?
i had a leak in the hose going into the heater core or whatever its called
it was spraying my drive belt... it was a good size leak
just have the car on, and check under the hood after it gets up to temperature, u should see it...
if theres nothing on the ground it could be goin into ur oil...
in which case u have a blown head gasket
Old Oct 17, 2003 | 08:30 AM
RENE95Z's Avatar
Dude, he's talking about a freon leak, not an oil leak.
Anyways, you can check out the auto parts store and they should carry some die that you can put in the system. I'm not sure if you can see it with naked eyes or if it requires a black light. But that should help you to identify a leak. Otherwise, take it to someone if you are losing it that quick.
Old Oct 17, 2003 | 08:40 AM
NewbieWar's Avatar
ohh heh i get antifreeze and freon mixed up sometimes sorry
Old Oct 17, 2003 | 06:45 PM
b-stevens's Avatar
Antifreeze
I put my car up on jackstands the other day and i noticed that there a green liquid underneath my car, but I had had my a/c die tested and there is also a similar color green on the cap to to metal tube that runs freon through it. Isn't freon a gas?
Old Oct 17, 2003 | 07:57 PM
RENE95Z's Avatar
When you put "freon" in your a/c system, you are putting a mixture of freon and oil in your system. So, when you are die testing your system, it is the oil that is colored for viewing (usually green).
Old Oct 17, 2003 | 08:13 PM
b-stevens's Avatar
ok so then its possible that its the freon/oil combination that I'm seeing because I already know that I have a leak in my A/C system. Thats a releif.
Old Oct 18, 2003 | 12:41 PM
crzhrs's Avatar
There use to be a dye you could buy, but now you have to buy a kit that uses a dye and an ultra violet light to find the leak. I heard it cost around $80 . Just trying to avoid buying that kit.
Old Mar 10, 2004 | 11:43 PM
phoenix916's Avatar
they carry recharge cans at walmart with the green dye in it.
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
