CamaroZ28.Com Message Board
-   -   where to weld cut out? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/where-weld-cut-out-189311/)
gritter Nov 4, 2003 10:53 AM
Where on my flowmaster cat back should i have the cut out welded?
madwolf Nov 4, 2003 11:03 AM
Check out the 2nd and 5th reply in this thread.
To summarize though, I had it welded on the intermediate pipe right where the other guy's pictures show, but I lost some ground clearance and ended up hitting a raised manhole cap with it, so I had it relocated to the location shown in the 2nd reply.
BlakeW5 Nov 4, 2003 11:44 AM
Don't know about the other thread just mentioned, but I put mine in the intermediate pipe right before it goes over the axle. Where I put it, there is just enough room to angle it sideways (dumping out the passenger side), so I lost no ground clearance; you can't even tell it's there.
teke184 Nov 4, 2003 12:10 PM
"you can't even tell it's there"
except for the awesome sound:cool:
i had mine in the same spot before the axle for 2 years without any scrapping.
i suggest maybe buying a turndown so that you can direct the exhaust away from the frame and axle
jasons93z Nov 4, 2003 12:15 PM
When i do mine im going to install it right before the muffler input. It sounds good, and its VERY easy access.:D
drewstealth Nov 4, 2003 12:22 PM
Do you have any pics of what that would look like? Thats where i was thinking of putting mine but i haven't seen anybody else do it there so i wasn't sure if there would be a problem.
