Whats wrong with tranny?
Old Oct 25, 2004 | 12:12 AM
dabez1's Avatar
After racing a harley devidson truck i noticed my tranny would "Thump" everytime it shifter mostly frrom 1-2. Now everytime it shifts i can feel a Thump as if the tranny would jump. the higher the Rpms the louder the thump. Could it be the tranny mounts?
what happens when the tranny is "Slipping"?
Old Oct 25, 2004 | 12:16 AM
TobyZ28's Avatar
Re: Whats wrong with tranny?
I'll bet the bank on your tranny mount being broken Quick, cheap and easy fix. Just buy a new mount.
The trannys basically bumping on your floorboards when the engine torques up...
Old Oct 25, 2004 | 12:28 AM
dmoor88's Avatar
get a poly mount and dont worry about it again.
Old Oct 25, 2004 | 12:39 AM
dabez1's Avatar
Thanks for the info, you made me feel better, just dumped in alot of money in another engine and wasnt looking foward to spend more on rebuilding the tranny. ill take it to a mechanic 2morrow.
Old Oct 25, 2004 | 01:09 AM
Hawk350's Avatar
What he said
Old Oct 25, 2004 | 01:06 PM
94Zpower's Avatar
Yeah but somepoly mounts will make your drive shaft vibrate like a ****!!! i made some 1/8 inch aluminum shims to lower the poly mount and set the pinion angle correctly because b4 I did that my car vibrated like crazy at 60+ mph. it was VERY aggravating!!
so check your DS angle b4 and shim it accordingly, and the you can forget about your poblem and enjoy your ride!
Mikes 1994 z28
Oct 10, 2015 07:55 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
