Whats WRONG???!?!??!?!?!?
My oil smells like gas. My radiator has foamy tanish oil in it.
But my brother was able to drive it 20 miles home. It didnt overheat. and it seems as if a fwe times while driving i could smell coolant.
Re: Whats WRONG???!?!??!?!?!?
Originally Posted by dmoor88
how does your oil look? what color is your exhaust smoke out the back when you fire it?
OK.....If no white smoke.. cracked block or cracked head.
If white smoke bad gasket or bad head.
One way to tell is drain oil and antifreeze, buy some cheap oil and put pure water in place of antifreeze.
let run for a minute.
check the oil and radiator.
if it's in both; once again only one of 3 things,
cracked block--worst case scenario
cracked head--second worse
bad gasket--sigh of relief.
