whats better???
94-97 LT1 SLP Adjustable Fuel Pressure Regulator
[25001] $59.99 Click to enlarge This adjustable fuel pressure regulator kit for the LT1 converts your non-adjustable factory LT1 pressure regulator to fully adjustable. Now you can fine tune fuel pressure for maximum engine power output and performance. Each kit contains a precision-machined aluminum cover, all necessary hardware and complete installation instructions. OR!!!! 94-97 LT1 Camaro/Firebird Aeromotive Fuel Pressure Regulator [13107] $159.99 Click to enlarge 94-97 LT1 Camaro/Firebird Aeromotive Fuel Pressure Regulator These fully adjustable, vacuum/boost reference fuel pressure regulators from Aeromotive are designed for use with GM LT1 engines. They were developed with LT1 specs in mind, to help your car perform at its peak. These are true billet, fully adjustable regulators, featuring CNC-machined aluminum seats, ports, and stainless steel springs, custom-designed for precise fuel control. looking to buy one of these thanxs for the replyss!!!! |
Re: whats better???
Most people don't need an AFPR. It only helps if your fuel injectors can't keep up with your power adders.
