what will tuning do?
just got finished putting in a hotcam. rr etc. the idle is pretty rough and when i'm driving and rpm's are at or below 1500 it is also rough. what will tuning (pcmforless) do for me? and should i get it? will it clear up my problems?
Yes, it will solve your rough idle problems. A reprogram basically corrects your Air/Fuel ratio which gives you more power. The Hotcam is a pretty small CAM and with headwork I don't believe you'll see much of a gain.
Maybe 20 to 30 RWHP.
Yes. Headwork will net you more. Not sure about exact numbers. There is a site somewhere that has a dyno printout comparing before and after Hotcam numbers.
I'll send you an email about the K-member.
Aug 24, 2015 06:41 AM
