What to use to plug AIR holes in SLP shorty headers?
Old Mar 11, 2004 | 03:04 PM
slider's Avatar
Just as the title of the thread says. I will be deleting my AIR system.
Old Mar 11, 2004 | 03:40 PM
Z95m6's Avatar
I just went to the local hardware store with a header in hand and bought 2 brass caps that would screw on.
Old Mar 11, 2004 | 03:44 PM
Hyperspeed97z28's Avatar
do a search... m22 drain plugs...
Old Mar 11, 2004 | 03:50 PM
slider's Avatar
Headers are on the car so I can't do that
Old Mar 11, 2004 | 03:52 PM
Z95m6's Avatar
That's for stock manifolds, SLP require caps not plugs.
Old Mar 11, 2004 | 04:00 PM
slider's Avatar
Does anyone know what I can use to cap them?
Old Mar 11, 2004 | 04:05 PM
Tires_Smokin's Avatar
Heres a link. Is this what you are talking about?
Scroll down a lil bit and you will see the block off plates.
SJM Manufacturing, Inc
Old Mar 11, 2004 | 04:12 PM
slider's Avatar
No, I'm removing the AIR not the EGR
Thats funny.. my 93 SLP shorties have m-22 drain plugs in both sides... been there over a year now....
Old Mar 11, 2004 | 04:42 PM
slider's Avatar
Did you just put the plugs in and that was it or did you use something to seal the edges too?
Old Mar 11, 2004 | 04:49 PM
ha, woops..i guess it is time for me to go home and get off work...I've seen guys crimp and bend the aluminum tube and then neatly apply JB weld or something. If you have a slp cai or air inlet thingy on your intake...use a cap and jb weld it.
Old Mar 11, 2004 | 04:57 PM
Chris'SS #2152's Avatar
Well, when I had my SLP's I used a cap from MBA. Looks very good also, in fact I think I still have them..I could sell them to you for cheap if you want.
Chris
Old Mar 11, 2004 | 05:29 PM
llafro's Avatar
Mine have 3/4" galvanized pipe caps from Home Depot. They are the single cat (94-95) variety, so it might be different. I saw somebody here say that Home Depot is a great place for car parts if you have some imagination...
BRAD
Old Mar 11, 2004 | 06:04 PM
transamtom's Avatar
BRAD
Thats what I did, only I used some copper RTV sealant on the threads.
Old Mar 11, 2004 | 08:21 PM
2cub49's Avatar
They're 3/4 fine thread so you could weld together 2 nuts and get 2 plugs or short bolts.
