What is thread size for smog fitting on headers?
For your 95, its M22x1.5 NAPA part number BK704-1048 They are like 8 or 9 bucks a piece.
If you want to go with a cheaper route, go to your local hardware/plumbing store and ask for 5/8 flare plugs. I used two of these. The size of the treads is the same, but the pitch is different though. Since it was brass you can cross thread it in, and it will do no damage to the manafolds. brass is a pretty soft metal.
Good luck with whatever you do!
ChrisFrez
Nov 23, 2014 10:33 AM
