what temp does your camaro run???
Old Nov 13, 2003 | 04:41 PM
whitedakota's Avatar
Arrow what temp does your camaro run???
i am just curious, i ordered a 160* thermostadt from autozone, i put it in, bled the lines, etc,...and my car runs about 175-180*...i was just wonderin if they ordered the 180 instead of the 160 or is that were its known to run?
thanks,
steve
p.s. went to track a two weekends ago, and pulled a 1.97 60ft, and a 8.89...all stock and 2.73's
Old Nov 13, 2003 | 04:48 PM
got_hp?'s Avatar
i have a 160 and my car runs 165 driving, 170 sitting.
i think thats probably too cold for optimum performance, ive heard closer to 180 is better.
Old Nov 13, 2003 | 04:53 PM
atljar's Avatar
Sitting it goes ~180, driving 170. 160 stat, CSI pump, and lower fan turn ons. My car stays warmer driving because it sits so fricken low the radiator gets little air.
Old Nov 13, 2003 | 04:54 PM
96z's Avatar
96z
Mine goes 180-190. With the stocker thermostat and CSI.
Old Nov 13, 2003 | 05:12 PM
Kataklysm's Avatar
Mines always around 170 with the hypertech 160 thermo.
Old Nov 13, 2003 | 05:26 PM
windnsea00's Avatar
180-190 running, sitting will warm up to 226 when fans kick on i need a manual fan switch! by the way my car is stock
Old Nov 13, 2003 | 06:58 PM
Seal's Avatar
170 driving 180 sitting, never passes the 1st line... even sitting for hours
Old Nov 13, 2003 | 07:21 PM
96Z28TealM6's Avatar
stock thermostat....when driving...it hits the first line and while sitting it stays at the last line before the redline.
Old Nov 13, 2003 | 07:28 PM
94GrayV6's Avatar
180-190 pretty much all the time.
Old Nov 13, 2003 | 07:30 PM
SVT Killer LV's Avatar
WOW.. That is nuts..
Mine is halfway to the first line driving, barely above the bottom line on the freeway, and right below the first line sitting... I also have the 160 Stat, reprorammed fans and the Felbro 1074 HGs, which have revised coolant holes...
Old Nov 13, 2003 | 08:27 PM
Tair's Avatar
I gotta get me one of them 160 stats!
Old Nov 13, 2003 | 08:34 PM
94 CAMRO Z28's Avatar
When sitting mine will almost get to the 180 mark. When driving it sits right between the first mark and the 180 mark. I have 160 degree thermo and the fan is programmed to come on early.
Aaron
Old Nov 14, 2003 | 03:15 AM
Prorac1's Avatar
i agree with bono. I did the 160 thermo and it didnt do dick squat. But with the fans turning on earlier (and a man switch for the staging lanes) the car never gets over 170 except when the a/c is turned on. Prorac1
Old Nov 14, 2003 | 04:36 AM
97WS6SCharged's Avatar
With the 160* stat, I get about 170-175 sitting w/AC on. When the car's moving, the needle is kissing the 0 on the 160 mark. I would have stuck with the 180, but with the supercharger, I wanted it to run colder just to be on the safe side. Don't forget to add the purple ice, that helps a lot.
Old Nov 14, 2003 | 08:39 PM
Laymaster's Avatar
my 160 stat, according to the car's computer, and this is about right from eye-balling the guage, runs 168*
