What size tranny cooler for 2800stall??
What size tranny cooler should be a minimum with my new stall and gears that went in??
To be honest, a tranny cooler is not something you want to go minimum on. Find the biggest and best you can find, your tranny and wallet will thank you later.:)
Hare's a good example of a big cooler: http://www.bfranker.badz28.com/94z/trannycooler.htm |
Snorkelface is right, biggest one you can afford.
I have a 24000 GVW in mine, the kind they use for motorhomes and crap. I paid too much money and puttin in the tranny was too much work to skimp on the things that will make it last. |
http://store.summitracing.com/defaul...&d=15&x=22&y=9
This one is particularly beefy. I would to get one of these, but I'm wondering if it will fit on my radiator with the twin intercoolers from a Procharger kit (plan to get one in the future) installed. Where are some alternate locations it could be mounted? |
Well the one I am putting in is a haynes 2600 xtreme duty. That work perfect you all think?
