What Size of TB?
Old Sep 25, 2004 | 05:33 PM
c0rey's Avatar
What Size of TB?
Hey the only thing I forgot to do when I installed the blower was to get a bigger tb. What size would you all reccomend on a stock heads/cam car. Later in the future the motor will be rebuilt with low low compression to get some good boost going on. I want something that I can use now and then use later as well. Here is the mod list to help you all decide.
Mod List.
ATI Procharger D1SC 8PSI
Walbro 340 Fuel Pump
Lucas 42.5lb Injectors
Taylor Wires
OTVC Looms
NGK TR6 Plugs
ODB1 PCM4LESS Coversion PCM
LT4 KM
Jet Hot LT's
Hooker Y Pipe
Magnaflow Catback
Granatelli MAF
Throttle Body Bypass
!Air
!EGR
Old Sep 25, 2004 | 05:37 PM
Z95m6's Avatar
Re: What Size of TB?
it sounds like if you later build a motor with heads and a blower cam i think you would want a 58mm tb. Only thing is that you have to pull the intake to port it for the tb. I know some people port it with the intake on but i would never chance it.
Old Sep 25, 2004 | 10:03 PM
ECIV_96_Z28's Avatar
Me niether. It's way to risky. I've seen a step by step, but way to many metal shavings produced in the process. You can go with the 52mm and stick with it or port it to 58mm and go with the 58mm TB. Seems like you have the money take it off and have someone port it and go with the larger TB...based on your mods so far.
Old Sep 25, 2004 | 10:11 PM
Z95m6's Avatar
You can port the intake yourself all you have to do is gasket match the TB. I don't know if anyone has tried it but you might be able to get a 58mm TB and run it on an unported intake until you have the manifold off to do your heads. Then you can port it.
Old Sep 25, 2004 | 10:47 PM
97WS6SCharged's Avatar
Opening up the throttle bores with the manifold on the car is actually pretty easy. I did it on my TA with no problems. FWIW, I think a Holley TB would probably work without porting the manifold. Mine is pretty thick, and I don't think the blades actually protrude into the plenum, if they do, it's not by very much.
Old Sep 25, 2004 | 11:08 PM
'97SLVRBullet's Avatar
Do they make a sinlge blade t/b now that is larger that the others?
Old Sep 25, 2004 | 11:18 PM
Z95m6's Avatar
Yes AS&M makes a monoblade. I think for most cars though that would be a little over kill.
Old Sep 25, 2004 | 11:50 PM
yea but he is going to be running a charger
Old Sep 26, 2004 | 12:01 AM
Yes but he's only running 8 PSI. In reality, the stock TB isn't a real restriction yet.
Old Sep 26, 2004 | 12:37 AM
chrism400's Avatar
That's my feeling.
Old Sep 26, 2004 | 12:38 AM
RedHottG2's Avatar
Put a 58mm TB on right now, it will be fine. Then when you pull the intake port it for the 58. You'll be alot happier with it over the 52mm IMO. Monoblade would be to much for you're set up as it sits right now. Get heads/cam then go mono. Also be sure to get a bigger fuel pump and an adj. fuel pressure regulator for the set up you have now.
Old Sep 26, 2004 | 10:48 PM
Hey guys, I've heard I can put a 52mm on my 96 Z with no problems....is the intake allready 52mm? Is it worth the money? How much HP gain?
Old Sep 26, 2004 | 11:24 PM
RedHottG2's Avatar
The stock bore on the intake is 48mm but you can put the 52mm on with no probs. at all. You didn't list you're mods, so I can't say if the 52mm would help you yet or not. A good rule of thumb would be to have all bolt on's and heads/cam/headers before going to a bigger TB. Hope this helps
Old Sep 26, 2004 | 11:35 PM
Z95m6's Avatar
The stock TB is 48mm but the stock intake ports are 52mm. 52 is the largest you can run anything bigger you need to port the intake.
Old Sep 26, 2004 | 11:38 PM
RedHottG2's Avatar
That's right DUH I knew that, damn it's getting late and I'm getting tired. I guess I need to go to sleep now.
