What Size Injectors?
Old May 31, 2003 | 11:46 AM
SantaCruz163's Avatar
I'm just wondering what size injectors, and what fuel system I should use if I plan on pushing 650+ hp at the flywheel? D1 compressor at 18psi. Maybe a 100hp shot later down the road.
Old May 31, 2003 | 01:22 PM
Dave Feerst's Avatar
There is actually a formula for Calculating the size on N/A cars but it wont work with a supercharger because the BSFC changes. I would think 36-42 lb. hour with an adjustable fuel pressure regulator for fine tuning and a darn good fuel pump is probibly what you will need, but do some more research. If you can find CJ he was running a D-1 with 14 PSI and I think 36lb. /hour injectors.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
