CamaroZ28.Com Message Board
-   -   What to look for in valvetrain for something wrong? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/what-look-valvetrain-something-wrong-245008/)
JJ's95B4C Apr 2, 2004 02:21 PM
I'm going to pull the intake this weekend to see if i can find where the clacking is coming from. What should I be looking for? Will the lifters be different if one collapsed? Anything physical that I will be able to notice when comparing them to each other?
shoebox Apr 2, 2004 04:46 PM
Put your fingers on the pushrod end of the rocker and lean on it a little. Do this while the engine is idling. If a lifter is messed up the pressure you put on it should change the noise or you might be able to feel something different from the others. Don't even need to remove the intake. :)
JJ's95B4C Apr 2, 2004 05:12 PM
Thanks shoebox! :bow:
SStrokerAce Apr 2, 2004 05:16 PM
The rockers might be loose or the pushrods could be too short.
Bret
