What header gaskets are you guys with ported heads running?
Old Jul 5, 2007 | 08:40 PM
  #16
speed_demon24's Avatar
Originally Posted by James Montigny
Hope they work for ya, use good 1" header bolts (preferably locking).
I have 1" breslins.
Old Jul 5, 2007 | 09:43 PM
  #17
user 647483's Avatar
Originally Posted by speed_demon24
I have 1" breslins.
I like those, they're well designed.
A lot easier to deal with than the 3-peice Stage8s.
Old Jul 6, 2007 | 03:40 AM
  #18
Joe B's Avatar
I also use the fel-pro's.....But with the LE2 heads "raised" exhaust ports, every header gasket i've seen has to be matched to the head ports(a dremel with a stone works well).....then "also" in almost every case, the upper end of the header flange and primary tubes NEED to also be ported out a bit for perfect flow through(from head port to header tube)..........a buddy of mine that just threw his LE2 heads on without matching his header gaskets and headers themselves picked up nearly 30 Peak HP after it was corrected at a later date.................Joe
Old Jul 6, 2007 | 07:12 AM
  #19
Old Jul 6, 2007 | 08:50 AM
  #20
Tricked-Out-Toy's Avatar
Ive used percys and they worked OK, but im super **** about header leaks and the tinyest leak will drive me crazy. The absolute best header gasket money can buy are the Earls. they have a hard aluminum frame and graphite/aluminum composite inserts that are AMAZING. never had a header gasket seal and stay sealed like them. Ive NEVER had a blow out and NEVER had the standard bolts (not locking) lossen and they fit my LE3's with no problem. Ive been running them for about 3 years now and LOVE them. I had them on my TPI engine and when I did the LT1 with the D-ports I just bought the replacement inserts and reused the aluminum frame.
Old Jul 6, 2007 | 10:48 AM
  #21
Yeah I was looking at those too. From what I can tell the regular SBC header gaskets have bigger openings than the LT1 gasket openings.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
jmzlt1
Mar 13, 2003 07:26 AM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
