What harness is this?
I installed my long tubes and this one's kinda close to one of the primaries down farther in the engine compartment. I'm just curious as to what is running on this harness. Red arrows point to the harness in question. Thanks guys!
Thanks Rob. I unplugged everything and wrapped the harness with a spark plug wire insulator that I had. I'm thinking it will be safe now. I didn't burn through any wires yet, but the wireloom was melted so it would have only been a matter of time before I charred some wires.
Trust me... relocate that harness or you'll have more problems down the road.
P.S. That harness also has your crank position sensor connector
i burnt that bad boy up on my 95Z that had mac mids. kept throwing a knock sensor code but started fine. only got one wire.
no it doesnt. the crank sensor is on the front of the motor on the bottom of the timing cover.
EDIT
Here you go:
Stab the harness through the motor mount bracket from the top. There is plenty of space between the two motor mount brackets to route your connections and it is beyond far and away from the heat of the primaries or collector. You zip tie the harness to the A/C line you see in the pic and you're golden. Just a suggestion.
EDIT
Here you go:
Looks like the PCM ground, starter solenoid, pass. rear 02, pass front 02, CPS and knock sensor connectors to me...
whitehooptie
Aug 10, 2015 07:02 AM
Henson071
Aug 4, 2015 09:32 AM
