CamaroZ28.Com Message Board
-   -   what does a valve grind do? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/what-does-valve-grind-do-749053/)
z28beast Apr 22, 2010 11:56 PM
ok so i had my good friends mechanic do my heads...he put in new seals put on my comp cams springs jet washed the heads painted them and did a 5 or 6 angle valve grind....what does that mean? what does a valve grind do? he charged me 200 for everything...ooohh forgot he also milled the surface to make it flat again..but what does a valve grind affect? am i going to get any better performance from the grind?
dangalla Apr 23, 2010 12:04 AM
http://lmgtfy.com/?q=what+does+a+5+angle+valve+job+do
