What do these plugs connect to??
2 Attachment(s)
I recently had a my 383 installed and while trying to clean up the engine bay, I noticed these 2 plugs disconnected and think I have an idea where they go or have went, but wanted to get a 2nd opinion. Thanks!!
Attachment 38269 Attachment 38270 |
evap purge sol. and AIR...
I think, not sure |
The one on the top will be for the EGR solenoid. EVAP is on the other side of the intake.
I had the A.I.R. pump removed when the motor/blower was installed. Do I need to do anything with these plugs or can I just cut them out of the harness?
Not knowing any information about what car you have makes it harder to say what might happen. You can remove them (as long as you do it cleanly), but you will likely need some reprogramming to keep any trouble codes away.
Shoebox, THANKS for the helpful website. My car is a 95 T/A with a 383 and D1SC. My tuner did tune out all the emissions on the car. Thanks!:D
| All times are GMT -5. The time now is 07:26 AM. |
