CamaroZ28.Com Message Board
-   -   What To Do Next? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/what-do-next-126272/)
Dmx4ever3 May 29, 2003 01:10 AM
What To Do Next?
hi just look in my sig and let me know what you would do if you were me :) JUST ADD YOUR .02 THANKS
Laymaster May 29, 2003 01:31 AM
cam.
Dmx4ever3 May 29, 2003 01:35 AM
Originally posted by Laymaster
cam.
OK what size im thinking some sup work and tires then that but im just looking to see what you guys would do :)
carlos64030 May 29, 2003 01:39 AM
If you're on a budget, get a CC 306 cam, get your stock heads ported, get all of the necessary hardware for the heads to work in concert with the cam, get some 1.6 roller rockers, upgrade to a heavy-duty timing set, and get a good dyno tuning. The most important thing, get a Haynes manual and do all of the installation work yourself! ;)
Dmx4ever3 May 29, 2003 01:41 AM
well i have no job put all my money in my car my girlfriend hates that and no tools and a creidt card :) but i really don't want to use it any more i ow 2700 on it:( :eek:
Laymaster May 29, 2003 01:49 AM
I'd say you need to pay off your debt.
But, if money were not an issue, whichever cam you decide upon is based upon your goals. Everyone says a good mild cam (if you're not into making a 12 second car) is the hotcam. Since you have a lot of mods, you might hit 12's. The kit with the roller rockers and springs and retainor clips cost $476 from Jason Cromer. All you need to buy are new gaskets....and tools I suppose.
The CC306 is slightly larger than the hotcam, but I believe it costs a bit more.
Cams can go a lot of ways, depends on what your goal is.
Dmx4ever3 May 29, 2003 02:00 AM
i don't know much about cams but i was thinking of a cam bigger then the hotcam anyway but not sure what i hear that the 306 is way to big or not a good street everyday type of cam i was thinkin a 224-230 dur.
