what can I do to bring the volts up 12.3 I need 13.5
Old Jul 27, 2008 | 12:43 PM
  #16
ulakovic22's Avatar
I think you should check the volts first before you keep buying new things and replacing stuff. If your pump isn't getting the correct voltage it won't perform as well. Verify that first. Also a voltage kit simply takes voltage from the alt. to your pump so you don't have the voltage drop through the stock harness.
Old Jul 27, 2008 | 05:07 PM
  #17
Originally Posted by Billet ss
I was thinking of just putting a racetronix harnss on,I see guys getting a volt out of that what do you think injuneer?
I think you should check your voltage at the fuel pump before you start rewiring things. That's why I already suggested it TWICE.
A buddy of mine had a prolbem with his battery in the back, and a single positive wire going up to the front. He had to add a second wire from the rear battery to one of the connections up front - I can't remember which one it was. But the problem showed up at high engine loads, when there was not enough power for his high end (8-coil) ignition system and dual fuel pumps.
I'd also be suspicious of running the original black battery ground wire to the post on the fender. That wire carries all the current to the starter. Running it through the small bolt that serves as the common ground on the fender doesn't sound like a good idea.
You never answered my question about whether you used a high-current rated master disconnect switch?
Old Jul 27, 2008 | 07:09 PM
  #18
Billet ss's Avatar
I dont have a dis switch,the ground wire is not on the fender it is grounded to the post and the motor mount.today the volts went up to 13.2 why I dont know but at the track I lost a volt during the pass it was at 12.0 but went right back up after?
Old Jul 27, 2008 | 10:50 PM
  #19
97SS0594's Avatar
i love my racetronix kit! power feeds off the alternator so your getting what a full 13.5 volts.
Old Jul 28, 2008 | 12:00 PM
  #20
Billet ss's Avatar
Where should I of have put the ground?
Old Aug 9, 2008 | 04:20 AM
  #21
Billet ss's Avatar
Were should I put the ground at instead of the post,I checked fuel pump volts it was 12.3?
Old Aug 12, 2008 | 04:46 AM
  #22
Billet ss's Avatar
I think I fixed the problems,I went to the track friday and with a volt booster and my alt went out cheap *** alt so I changed it,and the booster went out tobut I didnt put it back in,because caspers told me to get ac delco instead of a pepboys alt.I put a new alt and caspers fuelpump booster and the volts went to 13.?? I made a wot run and the volts didnt drop so maybe its solved
95chwagon
Oct 16, 2015 12:24 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
