What cam do i have? how do i check
Old Nov 4, 2003 | 01:50 PM
93transam1234's Avatar
Question What cam do i have? how do i check
I am pretty sure there is a aftermarket cam in my car how do i check the specs on it with it still in the car?
What are the stock specs to caompare?
THANKS
Old Nov 4, 2003 | 02:32 PM
LWillmann's Avatar
I believe there is a tool to measure lift at the rocker.
But, I'm not sure on this one though, I think you have to take the front cover and use a degree wheel to determine the duration for the cam.
Old Nov 4, 2003 | 02:50 PM
well
Does anyone have a pic of under the valve covers with all stock stuff...
I would think if it had a bigger cam they would have upgraded the RR and springs RIGHT?
Old Nov 4, 2003 | 02:54 PM
ead94z28's Avatar
You will need a degreeing kit to measure the lift and identify the cam. Why do you think you are camming?
Old Nov 4, 2003 | 02:58 PM
BradZ28's Avatar
Remove the drivers side valve cover, 4 10mm bolts and 5 minutes. No RR usually = no cam.
Old Nov 4, 2003 | 03:35 PM
GREGG 97Z's Avatar
Re: well
Stock stamped rockers
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
