CamaroZ28.Com Message Board
-   -   what all should i do to tuneup . . . (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/what-all-should-i-do-tuneup-466028/)
dallas63 Aug 11, 2006 12:34 PM
i have a 1996 z28 with 130,000 miles it still has original rotor , caps and wires . what all should i replace . i was thinking the water pump , wires , rotor , cap , maybe opti , pvc , fuel filter . any help will be appreciated . thanks jay clayburn
ulakovic22 Aug 11, 2006 12:41 PM
Re: what all should i do to tuneup . . .
I wouldn't mess with the Opti unless something is wrong. Everything else you mentioned would be fine. If you are going to replace the water pump I would get an electric w/p. Is there anything wrong with the car or does it run fine?
2000GTP Aug 11, 2006 12:46 PM
I would wait on the Opti and waterpump. Wires, plugs, PVC valve, fuel filter, air cleaners, and cleaning the throttle body would probably be as far as I would go with the tuneup.
rokudan Aug 11, 2006 01:55 PM
Just FYI, it's PCV not PVC.... Positive Crankcase Ventilation....
LT1Squirrel Aug 11, 2006 02:02 PM
seafoam it first...then do all the tune up stuff...add new 02's in there also
fredmr39 Aug 14, 2006 06:48 PM
O2's, mentioned before, should be near the top of your list.
1racerdude Aug 14, 2006 07:13 PM
Replace the WP with a stock rebuilt, before it goes to leaking and ruins the opti.
DO NOT use seafoam or any other additive on it. Along with what ya mentioned to replace have the oil and filter changed at the same time.
rokudan Aug 14, 2006 08:02 PM
Don't forget belts and hoses. Check them for wear and cracking, and replace appropriately.
fredmr39 Aug 15, 2006 05:02 PM
If you're going to replace the WP - might as well do the opti. So, either do both (pointless now) or wait until one craps out. If opti goes - definitely do the WP, if WP goes - replace that and you can save the opti for later if you are short on cash. Plus - just changing a water pump that is working could always create problems (e.g. spill coolant on opti).
Use seafoam - why not? Just don't add it to the oil. Of all the cars I've used it on - about half of them had very noticeable benefits while the others were average or a little above (in other words....no negative experiences - just stay away from the oil).
