CamaroZ28.Com Message Board
-   -   weird noise (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/weird-noise-666168/)
malw_95z28 Feb 3, 2009 11:38 PM
weird noise
im havin this weird noise 4rom my z. it seems like any hard acceleration it starts happening. its a weird sort of grinding noise. it comes 4rom under my driners seat. i feel it under my leg. my ges is my drivers side header is hitting the undercarriage. bcuz it stops after it shifts. it seems 2 me that it only does it at higher rpm's. u guys got any ideas???
mr.green Feb 4, 2009 12:17 AM
I dont think that it would be your headers grinding on your undercarrage. Is it a grinding or a small vibration.
malw_95z28 Feb 4, 2009 12:23 AM
its more of a grinding noise. at first i thought it was the asr bcuz it made the sade when my low trac light came on. but i turned that off and it still did it
Diamhea Feb 4, 2009 11:51 AM
Shorty headers? There are some clearance problems with those on our cars. Mine hit my k-member when the engine torques up and stops it from further accelerating.
malw_95z28 Feb 5, 2009 12:40 AM
no mines are longtubes. but that sounds kinda like my situation. it does it most around 3000 rpm but eases up further up. wat did u do 2 stop it???
Injuneer Feb 5, 2009 05:16 AM
Check the tranny mount and motor mounts.
CstIrnFst Feb 5, 2009 09:29 AM
I'd also check the driveplate/torque converter area. I just replaced my driveplate since it had a large crack right down the middle of it. It would cause a rather loud rattle/vibration that I could feel through the floorboard while driving. And it would happen at specific RPM's more often than not.
andysc Feb 5, 2009 08:17 PM
Not trying to hijack the thread, but how do you check motor mounts? Now back to you regular thread
tia
andy schuck
