Weight difference between LT1 and LS1 black?
Old May 18, 2004 | 12:37 PM
LT1ponykilla's Avatar
Weight difference between LT1 and LS1 block?
I was wondering what the weight differences were in these two motors. I hear there is about a 50lb difference from the LT1 motor and the LS1's. Is this correct and does anyone know the exact weights?
Old May 18, 2004 | 12:49 PM
DonHood's Avatar
I don't know the exact difference between them, but I'd assume the LS1 aluminum block would be considerably lighter than the LT1's iron block.
Old May 18, 2004 | 12:57 PM
Well I figured that much. I was wanting to know how much of a difference there was though. Probably between 50-90lbs.
Old May 18, 2004 | 01:38 PM
bunker's Avatar
I would assume the iron LS1 would weigh about the same as the LT1 iron block, so here are the exact figures:
GEN III V8 IRON BLOCK = 210.4LBS
GEN III V8 ALUMINUM BLOCK = 92.5LBS
Cylinder heads:
GEN III V8 IRON HEAD = 43.2LBS
GEN III V8 ALUMINUM HEAD = 18.9LBS
Other info:
* Aluminum will expand 1.7 times the amount of cast gray iron.
* Heat will flow through aluminum 2.4 times more quickly than cast gray iron.
* A sharp object will penetrate aluminum 25% deeper than cast gray iron.
Hope this answers all your questions, this is all GM INFO.
Old May 18, 2004 | 01:41 PM
Red96Lt1's Avatar
Good info. I didn't know there was that big of a difference.
Old May 18, 2004 | 03:14 PM
bunker's Avatar
Yeah its amazing we have to do a battery relocation mod & all tubular suspension just to get the same weight in the front LOL, its crazy
Old May 18, 2004 | 03:50 PM
Damn them LS1's.
Old May 18, 2004 | 04:07 PM
JasonL's Avatar
According to these guys, who dismantle a lot of cars, the LS1 block is 53 lbs lighter than the LT1 block.
http://www.hpsalvage.com/lt1.htm
Corvette Black Book says a fully dressed LS1 (accessories, etc) weighs 44 lbs more than a 1996 LT4.
Old May 18, 2004 | 04:25 PM
bunker's Avatar
hmm.. might be, I guess the LS1 iron block must weigh more, those are specs from GM.
Old May 18, 2004 | 04:36 PM
So which LS1's have the all aluminum block? Is it the 01 and 02 models?
Old May 18, 2004 | 05:18 PM
baron4406's Avatar
All F body and Corvette's use the aluminum block. In 'vette's its '97 and up, in F Bodies its '98 up.
Old May 18, 2004 | 05:27 PM
Ok, I was thinking about some of the 01 and 02 models having the LS6 block. Sorry, I know the LS1's are aluminum I was just thinking about something else.
Old May 18, 2004 | 07:31 PM
fstenuf's Avatar
our lt1's sure can take more of a beating then those ls1's
Old May 18, 2004 | 07:48 PM
AdamZ1LE28's Avatar
you got that right
My friends:
1999 Camaro Z28 LS1 28k miles- Last fall 13.2 @ 106
- Maybe 3,000 beaten miles 14.6 @ 100 this spring
2000 Trans Am WS6 6 spd 12k miles- Burns quart of oil every 2 days
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Dec 1, 2014 08:08 AM
Jul 4, 2005 05:00 PM
