water pump question
I've got a 95 and changed the waterpump about two months ago. I don't remember it exactly but yes, there is a heater line coming from the front lower passenger side of the pump... If I had a pic I would really be able to help you.
Idea - I've got my old pump at home. I'll check it out and let you know if nobody responds by late tonight.
And you're sure that it's not the hose that is going into the radiator to cool the coolant (I'm not at my car right now so going by memory from my water pump install). If it isn't, then that could be what you're looking at. Not entirely sure though. I'll check later
